toddlaine
What should I set my initial timing to? I Just bought a timing light and this is my first try at this. Any info will help but keep it as basic as I need.
Thanks,
Thanks,
Plugged Vac line and set to 12 initial . When vac is hooked back up the engine sounds off. Is this right or should I set inital with vac line hooked up. The timing light instructions does not say to disconnect vac line for initial timing only for total timing. Please help.
