Stock location or remote?
TheRacerDave
San Diego
Putting a 440 in a '73 Dart Sport that was set up for a RB. Will be using an external line oil pickup to the pump. Is it possible to use the stock filter adapter, or should I go remote? Also, car is equipped with a motor plate, not stock type block mounts.
When I built my Demon it uses a Milodon in the tank pick up and an external line to the pump. It uses the oil filter in the stock location. All this is with a motor plate. Fits really good.
Ted
Ted
Thanks, this is exactly the parts I have. What oil pan are you using?
This pan had started life as a Milodon 7 qaurt. But what we did was to take the drivers side a make it straight up. No problem at all.
Here is a photo. Contact me if you have any more questions.
