Strange Drag Brakes specs
subcom
South Florida
The Strange brakes I had on my Duster required the 9" drum brake spindles to work.
Your best bet is to just call Strange and not rely on advice you get here. Not that it's all bad, but you may as well get it direct from them to avoid issues.
Tom
So Strange support does not know if this kits moves the track width BUT the max hub diameter is 2.5”. Which means these would even clear factory 15” steel wheels potentially. Well, the hub at least.
