Sedanman
67-9 Valiant specialist
It is 52 1/4 from drum surface to drum surface. I spoke to a friend who has his springs moved into the rails on his 67 Valiant also and he said his drum to drum is 52". I was just trying to see what other people had in their car so I can see if this axle will work as a bolt in or if I have to mod anything. I haven't checked if it was cut for the axle offset in a Mopar. I think axle centers are centered in a GM where a Mopar it is offset and will have 1 tube longer than the other. If a factory BBP A body 8 3/4 with 10" B body brakes is 57 13/16 which is 3.5" shorter. I can always resell this axle to another Vega guy and just find a different housing to cut to my size. I was hoping to find something used that would be a bolt in and I don't ever get that lucky. The front inboard hangers were installed the way a fellow member told him to install them and leaving the factory locations intact incase someone ever wanted to go back to stock. The front hanger is flush to the outside of the rail but sticking out the back. I was just hoping someone had a similar set up I could get some basic ideas from. Thanks for the input.
