bluefish1967
Recently purchased a used 570, in the box. Looks to be new or slightly used. I disassembled to inspect, checked all of the gaskets, jets, power valve etc... all are factory sizes. I removed the 600 Holley from my mild 318, and installed the 570. The engine would not start, as fuel was dumping into the carb as if the floats were stuck. After disassembling again, I found that the power valve does not screw in flush with the metering block, thus raw fuel is being sucked thru.
My question is, does a metering block from a 600 Holley interchange. And if so, why are the jet sizes on a 570 so much smaller than a 600 ( 54 main jets versus 66 on a 600 ). Thanks. Larry
