Street shifter recomendations
Transmission and Drivetrain Tech
  1. The Furnace
    The Furnace Well-Known Member
    69
    10
    Nov 13, 2014
    michigan
    Local Time:
    3:35 PM
    I Have a 76 dart sport with a 360 bored 30 over, rpm air gap intake, 600 edelbrock carb, 727 torqueflite tranny. Im Running hedman long tube hedders, and using the mancini racing kickdown cable with the BPE throttle cable kick down cable holder. I will probably not do a lot of racing but want get away from the column shifter and linkage. looked at the B&m star shifter and also the turbo action cheetah shifter. looking for feed back, pics of other peoples set ups from a cable mounting prespective if anybody has any. thanks
  2. gumper
    gumper Well-Known Member
    352
    29
    Jul 29, 2008
    Local Time:
    1:35 PM
    I've been using the same B&M quicksilver shifter for 14 years. It's had thousands of ratchets, and never an issue. It's a clean setup too with no extra handles or buttons.
  3. Woods74
    Woods74 Broke Senior
    5,983
    216
    Aug 21, 2010
    Seattle, WA
    Local Time:
    12:35 PM
    ^yup, I have the Hurst Promatic, witch works the same way. Love it!
  4. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,884
    868
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    2:35 PM
    I'm using the B&M Quicksilver and like it. Only problem I had was the ball kept coming unglued from the mounting nut so I replaced it with a T-handle. I installed it under the center console. Had to make a custom top cover plate for it as the one that came with it was too wide
  5. mopardude318
    mopardude318 Well-Known Member
    9,659
    807
    Jan 7, 2005
    Gilroy, Ca
    Local Time:
    12:35 PM
    the turbo action cheetah shifter is a real nice unit.
