1bad360duster
- Joined
- Dec 2, 2009
- Messages
- 315
- Reaction score
- 170
So, I’ve read about most of the oil mods done to 360 blocks. However, not sure what would apply to my build. I’m using hydraulic roller lifters so I can’t tube the gallery/block off oil there. So what if anything should be done for a stroker small block that will be shifted 6500-6700 max. Right now I have a high volume oil pump, milodon pickup-deep baffled pan and profiled crank scrapers. Besides profiling pump entry etc not sure if anything else is really needed. This is a 5.9 magnum block oiling through pushrods
