Strut Rod and bushing check
440 Mike
Minnesota
Can I use the 68 style strut rods on a 73 K frame? Are the Moog K7040 bushings what I need for this strut rod?
Yes you can. Use the bushing set without the inner sleeve. I believe it is k7040. The other set has a sleeve and 2 different size washers. I have both sets in the box. I can look to make sure what is in what box if you need.
