Tjhoward84
1969 Barracuda Convertible
I have a slightly used (less than 6 months) vacuum pump for power assist brakes. If you have a engine with a tall cam and you don't produce enough vacuum from your power brakes to operate correctly, this pump to will the necessary vacuum to the braking system. This unit has an internal switch that turns on at 15 inches of vacuum and turns off at 20 inches. It also comes with all the necessary vacuum hoses, hose clamps and wiring with fuse link.
This unit costs $270 thru Summit Racing.
Price: $225
I will ship via the USPS Priority Flat Rate Medium box for an additional $12.65
Price: $225
