Super 6 conversion
Slant 6 Engines
  1. dartlove
    dartlove Well-Known Member
    181
    34
    May 5, 2013
    northern Ca
    Local Time:
    9:26 PM
    Does anybody know where I can get all the correct brackets and kick down linkage to do a super 6 conversion. My son was given a super 6 intake & 2 barrel carb. Started to do the conversion then hit a brick wall. Turns out he needs a few missing parts.
    Or maybe what cars or trucks to look for. Any help would be appreciated.
  2. my68barracuda
    my68barracuda Well-Known Member
    1,019
    682
    Dec 6, 2009
    Indianapolis IN
    Local Time:
    12:26 AM
    Put a posting in the parts wanted section. The kick down linkage can be hard to find. Go with a Lokar cable kick down for a 904,
    Installs and adjusts easy.
    • Agree Agree x 2
    • Like Like x 1
    • slantsixdan
      slantsixdan =..=
      6,410
      1520
      Jan 7, 2007
      Vancouver BC
      Local Time:
      9:26 PM
      Factory kickdown parts have grown scarce and costly. See this thread for kickdown options. What kind of car (year/model) is your son driving? If it's a pre-'67 car with the rotating-rod throttle linkage (or heck, even if not) you might want to look at the parallel 2bbl setup article as an alternative. Photo documentation of a very well done such conversion is here.
      Air cleaner also depends on what kind of car he's working on. If it's a '60-'62 model or it has A/C, that makes it harder to find an air cleaner that'll clear everything. If not, that makes it easy (can just use a 2bbl V8 air cleaner).
      • Like Like x 1
      • dartlove
        181
        34
        May 5, 2013
        northern Ca
        Local Time:
        9:26 PM
        I have had quite a few people say that. I will look it up
      • dartlove
        181
        34
        May 5, 2013
        northern Ca
        Local Time:
        9:26 PM
        63 valiant, no a/c. have 2bbl air cleaner.
      • dartlove
        181
        34
        May 5, 2013
        northern Ca
        Local Time:
        9:26 PM
        Currently has Demon throttle pedal & cable
