any one know where i can get a manifold or a hole kit to put a 144 or a 174 supercharger on a 440 i know its been done i just can't find where people got the parts to do it
The 174 is good upto 468ci. The 144 is a little small for a big block.
Im running a 174 on a 360.
As far as the intake manifold, you can use a 6-71 with an adaptor plate to neck down to the 174 bolt pattern.
I have a 144 on a small block brand-x and it is not enough. 12.0's at 113mph @3555lbs. A 174 would have been a better choice. On a 440 Mopar I would use a minimum of a 250 but for what you spend on that may as well do a 6-71. How fast do you want to go? If you just want low 11's then the 177 can do that on pump gas! If you really tune the chassis you can go 10's.
