LXguy
Hey All:
Tired of this stuff taking up space on my bench.
Selling this sure grip differential. Was purchased new and original gears replaced with hardened units (Ma Mopar forgot the heat treat on a batch - oops).
I got rammy and upgraded to a detroit locker while I was waiting, so this hasn't been used since being cleaned and rebuilt with new clutches gears and side bearings. Will also include ARP ring gear bolts I had intended to use.
$300.00 (you can't buy a regular one for that, and it might have gears with no heat treat!)
Mopar Cone posi, works. I just removed it because I wanted better 60' times.
$100.00
Sorry for the bad pic!
Also have a fresh, cleaned 489 center with Mopar 3.91 pinion gear. Matching ring included. Original Mopar gears. Fresh, never run setup with new bearings, new crush sleeve, shim, etc. small yoke. Pickup preferred on this.
$100.00
Another bad pic:
Also have some open carriers, 489 hoghead with 3.23 gears and open carrier, empty 489 cases. Prefer pickup on the heavy stuff, but money talks! Let me know what you need.
Thanks!
$100.00
$100.00
Another bad pic:
Thanks!
