I have an issues that hopefully someone else has dealt with. I have a 65 Cuda with a 511 low deck 727 and 8 3/4 it has a 411 gear that I just installed replacing the 456 because I was hitting the rev limiter with 7000 chip at about 1000 ft . I am rapping the rear springs so bad that the driveshaft u joints are hitting. It has superstock springs and I added traction bars that I have set loaded. It also has a pinion snubber that is also set loaded. I have wheelie bars that we raised to 11 inches to see if they were causing the rearend to unload and as I left the line they are actually touching the ground. Has anyone else had this problem and how did you resolve it
