Dorian
dorian
I have a 68 Barracuda Coupe with a mild 383 and 4 speed. It has a Hayes flywheel and Centerforce Dual Friction clutch setup.
Here is a list of my upgrades to the car.
-SS Springs mounted on 3/4 inch offset perches.
-2x3 welded frame connectors.
-Dana 60, Strange 35 spline axles and spool. 4.56 pro gears.
-M/T ET street slicks 26 x 10.5 x 15.
-Just suspension poly front end rebuild kit, with upgraded disc brakes all around.
-Competition Engineering 3 way adjustable shocks on all 4 corners.
The car weighs 3140 with me in it and I launch at 6000 rpm and shift at 5800.
The problem is that when I launch my tires tear up a patch of the rubber on the starting line. The front end raises up on launch as well as the back end after that. It launches hard and straight, but I am getting flack from the prep guys at the track, they say that I am the only one tearing up the starting line, and have requested that I try to remedy the situation for next year.
Any suggestions?
Thanks
Dorian
Any suggestions?
Thanks
Dorian
