I have been looking into swapping out the La 318 in my car for a Magnum 5.2. I want to keep the manual overdrive trans in the car. I know that I will need a intake, already have a carb. I will also swap the ignition over, and use the dakota manifolds. Are the engine mount the same? What flywheel will I need to run the 10.95 clutch I have, is it externally balanced? Can I get 300hp with a cam/spring/lifter and intake swap? I am planning ahead, still have not found a 5.2 magnum. Anybody have advice, good or bad. Thanks in advance..
This will be going in a 64 Valiant.....the La engine I will take out will go into another project...
