daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
Ok here is the story. I have a 66 valiant convertible with stock 273. Not long ago I happened to notice a sway bar tab on the passenger side when I put new wheels on it. I was scratching my head because I didn't think they came out with sway bars until 67. I guess my lower control arm must have been replaced at one time.
So I figured that I could find a lower control arm from a 67-72 a-body and then I could have a factory sway bar. I found one at a swap meet and the guy said it should work fine on my car and all I would have to do is drill some holes into the K-frame for the mounting brackets. I just found out tonight that nothing matched up at all. I have no idea where these brackets would go. Any of you guys have a 67-72 sway bar in your 63-66 a-body? Also, it seems like the sway bar is a little wide. Do I need aftermarket mounting brackets? Or will this even work?
Thanks
Thanks
