sway bar kit question
7duster4
Cincinnnati, Ohio
Will a sway bar kit for an A-Body up to 1972 fit an A-Body from 1974 (Duster) I would imagine the suspension would be almost the same during all those years. It's a front and rear bar with all hardware from Addco. Thanks
I think you should ask Ace .He has a 1974 Duster with an Addco and he hanged the rear bar on the frame!! He should know best!!
For the fronts, the 73-up pass through the K-member, and if I remember, the 72-older go under the K-mem. I don't think they are interchangable.
The bar designed to go through the k-member wouldn't fit workon the early design for obvious reasons but the bar designed to go under or around the K-member should work with either type K-member.
speaking of sway bars
does anyone know what kit to use for the rearof a 70 duster.with a dana 60 rear?
mike
Since there were no A-bodies (the SS car not included) that came with a Dana 60 so you will likely need to do some level of fabrication to make one fit and clear the center section.
