straightlinespeed
Sometimes I pretend to be normal
Hi guys,
I have a set of 72 lower control arms here at home. One side has a factory tab the other did not. I decided to bring them into work and have someone fab up the tap. They got it done and its not perfect but close to factory looking. They had everything dimensionally wise very close. with the exception of the hole. They totally forgot about the distance away from the arm.
The factory tab the hole is about 1" away from the arm. The one they fabbed up its about 5/8" away from the arm. This will cause the link to be tilted and more of a angle than factory. Will this be a problem at all? Im not sure about all the geometry and how this may effect it. Should we remake the tab? Thanks guys?
