Swinger Tight Window Issue
UPDATE
So I got both my door glass done. I ran into a minor issue where my glass did not roll all the way up, there was about a quarter/half inch for it to travel. I saw a thread on here with a member having the same issue (before I ran into the same problem), but I cannot find it to post the solution.
So for anyone having this problem, here's the solution.
The window is not rolling up because the (probably newly installed) plastic glass channel is hitting against the rubber vent seal at the top of the frame, the solution is to trim back the plastic so it does not contact the seal. Obviously, prevention of this problem is to not install the plastic right to the bottom of the glass curve like Ive seen in vids, but leave it about a half inch below. @Dana67Dart posted this pic which appears to be a worn factory strip, and clearly the factory left it a bit below the curve of the glass.
Hope this helps people out.
There is also an up stop. Be sure that is not the problem.
When I did my driver's door glass I did duplicate the notch
