switching door
wireweld
South Dakota
Will the doors from a 73 to 76 swinger fit on a 72 swinger? I would like to get rid of the vent windows and I thought if that would work it would be great.
There's more to it than just switching the door. The profile of the ventless glass is different from the PVW door. It may require only a change to the ventless glass door gasket. Without seeing the two side by side, I can't say.
You can do it. It will work. But you will also have to change out the roof rail trim and wetherstriping from the same year door you will be using.
Other members have done that change.
I'm still contemplating vent window delete for a 67 cuda vert. The top of the door glass will probably be the killer for me. Good luck with yours.
I did the reverse of what your doing '72 doors on a '73 .You will need to change the channel that the weatherstripping fits into.I have them if you want em, I'm in northern california.Feel free to PM Me if you need any additional info.
