dustbull
Hey everyone i have a quick question for anyone who has any knowledge about t-56's. I think i'm slowly losing the 2nd gear synchro in the O.D. A-833 in the duster
since the car was originally a /6 auto, it has a hydraulic throw out bearing in it now, and i dont care about how much of the floor or crossmember i will have to cut..but i looked at a few places and cannot find out the bore/stroke needed for the master cylinder to work with the stock t-56 slave cylinder, does anybody know it?
I also need to look into the clutch for this swap. The scatter shield for this swap allows for a clutch no larger than 10.5" so that should mean that i can keep the flywheel i'm currently running. I believe i have a 10.4" clutch rite now. Is it possible to keep the pressure plate and just purchase a 10.4" clutch disc that has the 1.125" 26 spline input on it?
Finally i am planning on purchasing a damaged t56 for under $500 and rebuilding it myself. Would you recommend i go with the stage II kit or would stage I be acceptable for my application (small block 408, maybe a low boost turbo one day, but always will be a street car)?
The way i see it, it should cost me about $800 more to get the t56 than just rebuilding the 833 but to me it is justified by the better gear ratio's, durability, and the two extra gears that come along with it..plus then ill have an excuse to put that badass viper logo somewhere on the car...Thanks for any help towards clearing this up!
