72BBSwinger
You're using stuff designed for the Challenger, i'm saying you didnt have too.
Found a pic of a Challenger TR6060 and the input shaft is splined twice what a Viper input is.
http://www.speedysgarage.net/challe...de/images/challenger_mcleod_update_01_web.jpg
Thanks for the info, looked all over for a proper pic of a tr6060 input shaft, guess I suck at the internet since I didn't find it.![]()
You should see if ACT has a thinner floater plate. That would make the clutch package more compact. I know that is the difference between a Challenger McLeod RST and the one I'm gonna use. Also the Challenger TR6060 and the Viper T56 have same input shaft length.
Wow, good suggestion. Would be very simple and effective...
Your diagram is of an early GM T56. Your T56 has a one piece countershaft. Also here is a pic of a Challenger RST clutch on the left and a "normal" RST on the right.
http://www.speedysgarage.net/challe...de/images/challenger_mcleod_update_02_web.jpg
Give me a couple days and I can measure mine, which is what I used with your pressure plate behind a BB. I used aluminum, but the dual disc is gonna need a thinner one it looks like.
When they're in the 1/2" thick range i'd say yeah! Plus the trans and tob are aluminum already.
I updated the T56 swap thread with its dimensions. Hopefully I will know if I cant use it soon. You will also need to make sure it is what you need first.
