Jun 11, 2009 #1 Wes 67Cuda Joined Oct 23, 2008 Messages 105 Reaction score 0 Does the tach wire connect to the negative side of coil?
Jun 11, 2009 #2 Burntorange70 Well-Known Member Joined Feb 18, 2008 Messages 12,870 Reaction score 152 Location Aguanga, CA. Yes it should go on the negative side.
Jun 11, 2009 #4 cudajim cudajim Joined Jan 17, 2006 Messages 1,512 Reaction score 117 Location Grass Valley, Ca. Wes said: Does the tach wire connect to the negative side of coil? Click to expand... If you hooked it to the positive side the voltage would not vary and you'd never get a signal for the tach so yes it has to hook to the negative side. It's simply looking for a modified pulse waveform to make the tach work.
Jun 11, 2009 #5 Wes 67Cuda Joined Oct 23, 2008 Messages 105 Reaction score 0 Thank you Jim. I commend you for tackling all these electrical posts!
