what is the correct name of the body sheet metal where the tail light housing attaches to the car is it spot welded from inside trunk or outside does anyone sell repops
The taillight opening is what I call it. It can be drilled off from the outside, as it is an easier job to re-install the new panel. There are not any reproduction pieces that I am aware of, so the only option is used. Try to contact member Lee Robinson out of California, I believe he still has a nice used pair, that has been drilled off, and are in very nice used condition. I hope he can help you.
