RPMLegends18
Hey guys. I just finished swapping a 73 rear end onto my 74 Dart swinger. Quater extensions tail panel...everything. Now I am trying to figure out the wiring. The 74 wiring harness has 6 wires, one black, two pink, one green, one brown, and one grey. The 73 has 7 wires. Three black, one pink, one green, one brown, and one grey. My problem is I cant get the right rear brake light to work. The right tail light works but no brake light. I followed the brown wire, which by the book is supposed to be the RR brake light to the plug before the loom goes through the tail panel. And it lights up the test light at the plug but it will not light up the side of the socket. Which I think is where the power for the brighter brake part of the light is supposed to come from (I may be wrong) But at that same brown wire at the plug if the lights are on it lights up the test light. Soooo this is what it does. Lights on it the "low beam" part of the light works, but step on the brake pedal it shuts off completely. With the lights off and pressing the brake pedal it lights up but only the "low beam." The left side and the license plate lights work fine its just the right side. Sorry for such a long post but I wanted to make sure I got everything down. Any help is much appreciated on what to do. Should I peel back the loom and see if there is a short somewhere or something? Could the socket itself be bad? Ive tried changing bulbs to make sure it wasnt something simple like that. I also tried cleaning the inside of the socket.
Thanks,
Ryan
Thanks,
Ryan
