tailight panel
thanks but i got it all just wondering if it can be done i see that the bumpers is different
Limelight, see this thread: http://www.forabodiesonly.com/mopar/showthread.php?t=90576
72340, It can be done but you will find a few differences. The brackets for the tail lights, and a couple other brackets back there. I think I may have a set if you need them. Also, the back edge of the trunk pan is different. On the '72 it is straight across the back, on the '74 that back edge has a couple "indents". I used a '75 trunk pan in my '72 and just used a couple thicknesses of sheet metal welded in to fill the gap. Worked fine.
I can't address the bumper issue, but I don't think it would be a problem to use a '72 bumper and brackets.
C
You might want to try Auto Metal Direct if you are wanting to do that. They have the '70-'71 tail panel, reinforcement brackets, and tail light brackets.
i got everything but trunk floor and filler yeah i will hve to fill in where that big ol bumper was
If you are looking for the frame rail end cap, I have that too. Along with trunk pan.
