71_dart_swinger
So it's been a while since I've been on here.
Updated 71 dart swinger.full interior. I'm curious what u guys think it will run. Set up as follows.
74 truck 440 .30 over 9.5:1 comp
915 heads.ferrea valves, Howards custom grind cam. Hydraulic roller .565 lift both sides. 294 303 duration. 440 source pump and housing,torker intake Sanderson headers. Taylor 10mm, mad pro billet,msd6al2.fuel is all aeromotive. Fuel pressure constant 6.5 psi. 727 3800,full Manuel reverse vb, narrowed 8 3/5 4:30grs 29x11.50x15 Hoosier dot drag slicks. Mini tub. Cal-track set up rear... I also just ordered a nitrous kit that I will be doing 150 squeeze. .. I'll be running at the next famous event....I'm hoping low 11s on motor. Mid 10s on spray?
