Dusterdenovo
Contentedly Old School
Going to be tapping an NPT hole in my Aluminum Tranny pan for a temperature sender. Speedhut supplied an adapter (3/8" NPT) to use with the Sender (1/8" NPT). I'm wondering if it is better to use the adapter with the sender or just use the sender by itself. Concerns are: optimal depth of sender into pan; adequate ground for sender with extra thread joint; potential for leaks; serviceability down the road i.e. replacing the sender if tapped right into pan etc.
Thoughts?
Thoughts?
