Temperature Sender
SABLT194
PA
I'm trying to find a temperature sender for a SBM 71 Dart BUTTT, I'm looking for 3/8 NPT instead of the stock 1/8 NPT. This is to go in my SBM Eddy Super Victor intake. For some unknown reason Eddy put 3/8" NPTs and no 1/8" NPTs. Trying to avoid a reducer bushing if possible but sometimes you gotta do what you gotta do. 69 Camaros had a 3/8 sender but it doesn't look like the resistance curve matches up at all.
Regards,
Steve
Nothing wrong with a bushing. Brass is better than cast or steel. Use pipe dope instead of teflon. You might have to find a good pipe supply house to get a 1/8' x 3/8" bushing. Mopar was always 1/8" temp senders, so you will be hard pressed to find a 3/8".
Home Depot has the bushing.
