Testing Instrument Panel on 70 Dart
garettrice
New Member
eugene
70 Dart. I've been narrowing down the problem on my fuel gauge. Done all the test on the sending unit and gauge. The gauge still works their is no power somewhere after the volt limiter on the cluster. It is a new volt limiter and their is power just after it 5 volts and no power coming out of the gauge to sending unit. I think the problem is the circuit broad on the back of the cluster. Also I noticed on the fuse box the orange wires the come from the instrument panel fuse test for 0 volts. Does any body know what the orange wires power on the instrument panel specifically? I cant seem to find a detailed wire diagram for the instrument panel. The orange wire shows 0 volts at fuse box but there is voltage after the volt limiter. Any help would be awesome. Thanks!
