If I'm not mistaken one spring will be the same diameter as the one that you originally pulled out. But unfortunately you didn't originally pull the original one out. Hopefully they left you with the original one?
The piece that you're holding by the fingertips. I was looking at these for the instructions and had ground there's like a lathe and tapered it and was having problems and I can see yours is ground down but not enough possibly? I'm going to look at the instructions again but I believe that piece needs to be ground down to the width of the piece that you're holding?View attachment 1715343426 View attachment 1715343427 had a tranny shop rebuild my 904 and do the tf2 while they were at it a while ago. I have a ratchet shifter and haven’t been able to get the 1-2 shift to be quick like the 2-3 shift. I took out the valve body today and was looking things over to see if there was an issue and I found the tv spring was incorrect per the tf2 instructions and the “B” section of my 1-2 governor valve not ground. I’m to grind that down per the instructions but the instructions say to use the yellow or pink spring for the tv, why do you choose one or the other? Thanks
Band settings are good, no restrictor plug isn’t that for 727s? This is a 904. I didn’t catch the line pressure adjustment on the valve body before I took it apart. I have since reassembled the valve body with the necessary changes and made the tab flush per the instructions. Going to talk to a coworker about using his lathe to grind the governor down. Will keep you posted with results. ThanksHave u checked the band settings yet?Is there a restrictor plug in the case for the high gear apply passage? How many turns from flush would u say the line pressure is adjusted to? Count the threads. Shifting is influenced by how much clearance is built into the clutch packs. The land on the governor should be ground down. The tv valve should be ground down, but it really not nessassary. Kim
Yeah I’m going to get that governor ground down in that spot going to talk to coworker about using his lathe. I’ll keep you posted upon assembly.The piece that you're holding by the fingertips. I was looking at these for the instructions and had ground there's like a lathe and tapered it and was having problems and I can see yours is ground down but not enough possibly? I'm going to look at the instructions again but I believe that piece needs to be ground down to the width of the piece that you're holding?View attachment 1715343603
There are 2 different throttle valves & plungers for the valve body differing in diameter. I think it depends on the year of manufacture. So you use the yellow or pink spring, whichever one is the same diameter as the original.but the instructions say to use the yellow or pink spring for the tv, why do you choose one or the other? Thanks
Yes I did, you can't always trust the "Experts", lolGreat. Maybe u learned something today. Kim
