thats play whats is called and where do i get one
sgd128
I'm looking for the ring around the filler tube in the trunk ..you know the one on the trunk floor..god what is it!! you know connects the filler tube to the tank but not really.. you know RIGHT, its the ring thing. its got like 5or6 screws holding it to the trunk floor......1970 dart..
Thanks ..i'm also look for the metal ring that holds it down..should i check the same place??..anybody here have one?
I'm not aware of a metal ring that holds it down.
C
First off what the beep are you doing with a picture of my wife in your Avatar??..yes, thats the rubber gasket but mine has a steel band aroud it...i'll see if i can get a picture..
