Pops6T6,
I agree with Rusty and Mopar on this, and most everyone has their own advise building their preferences but I believe it's necessary benefit to know your CR. I would zero beck the block per Rusty, great info!!! What he wrote is exactly what was done to my 340, CR is about 10.25 to 1 with KB 107 fitted with a 49000 head gasket with a Eleb performer and equipped originally with a 680 holly vacum secondary. IMO previous owner over cammed without actually doing some homework , therefore he popped in a purple 292/508 with what a 2000 TQ - What a slug!!. IMO the carb selection wasn't proper for the build, Car was fitted with an 8.75-3.23 (thats a good gear for BB's) sure grip and 727 Streetfighter. Car was a absolute pig off the line and would eventually pull kinda OK at 3500.
Like you I'm not going to beat my thousands invested on the drag stripe, but I want performance for the street with an awesome sound: I keeped the cam (Sounds great) plus i like old school **** cams, changed the TQ to a PTC 3500, replaced the gears to 3.55 SG, Went with a QF 650 DP (called and gave them the exact engine diameters) and junked that Eleb performer for an air gap! It was like day and night. No doubt that I'm in the high 12's or low 13's now. I'm currently in the process of having a set of RHS LAX stage 1 heads being worked at SD, they will be in later next week and my cfm will be dramatically increased. I'm not a fan of strokers, yes a 416 would kick *** but its also expensive. Anyway, thats what I have going on, your 360 is basically the same, bigger bearings, stroke but willl also kick *** if done right.
