The FINAL Wheel Backspace Thread for 1967-1969 Darts
19_El-Darto_68
PA
Ok, probably not....but,
I guess I just need to know what BS is going to work with my Factory A-body 8 3/4, mini tub and spring under frame relocation...
Will a 15x10" wheel with 7.5" BS work with a 12.5" cross section tire?
Planning on moving the axle back about .75" as well so I can use a 29" diameter tire if I need to.
I can't tell you for sure.... but that sounds about right.
I have a pair of factory-made centerlines that look like they were made for your exact situation. 10 1/2x15, 7 1/4 backspace, 5 on 4 pattern. They have been double drilled to 5 on 4 1/2. They are basically a 15x7 front half, 15x14 back half.
That's pretty cool. How much room do you have between the inside of the tire to the rear spring?
I haven't mounted them yet, haven't moved the springs under my Barracuda. The wheels shown on the car are normal 15x8 1/2 with 4 7/8 b.s. I'm using a .300 spacer to get the slicks away from the springs, so a 4 1/2 bs would be right. So a 3" spring move should need 3" more backspace. (And the blue car has had the rear moved back an inch, too)
IF you have mini-tubbed it along with the spring move, the wheel tire combo you suggested should be close.
