The holy grail of motor mounts
Jim - Do you think the 2710 motor mount will work for a 318 in a 66 Barracuda? My current mounts are sagging and my steering rod is rubbing a starter bolt. Thanks!
Yes, I think it will. I suggest grabbing one from Napa, or wherever is convenient, and get to work! Good chance you'll need to drill the guide hole, as I did, in the engine mount. Good luck!
Jim, one more question. Are the mounts different from the drivers side as opposed to the passenger side?
hello, there was a talk of that you are still using a 4 speed tranny correct. do you know of anybody with a 727 in early A's. I have 65 factory 273 car, I believe there mount will solve that problem I have but not the other problem.
