[WANTED] The usual SBP disc brakes setup
If you have 10" drums checkout the scarebird conversion brackets. The 10" drums use the same bearings as the sbp Kelsey hayes discs. The 9" drums have tiny bearings and I would not convert them to disc.
The rotors have to be drilled every time if you have to change rotors on the scarebird swap right?
I think they are toyota previa rotors and yes you need to alter the bolt pattern to make them fit.
