[WANTED] Thermoquad carb 6455S, 1974, 360 engine HP
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Looking for a good core ready for cleaning and rebuilding
1/2 primaries, 800 CFM,
360 HP, l974
Still don't understand the difference between 800 and 850 cfm
I have lots of spare parts,
the main things I Need :
1 No frozen idle mix screws
2 All linkage undamaged and operating freely
3 fuel bowl lid , fuel bowl, and throttle plate to be all good
I have this one to use now, need a duplicate when I get the MOD MAN
Magnum intake with the dual carb option
The 1 1/2 primary is the 850. The 1 3/8 primary is the 800. There's the difference.
I'm not too sure about that, I'll do some more research
Anyone else want to address this. ??
Ok i have a 1974 360 ambulance carburetor #6410 s, with 1 1/2 " primaries . Its identical to yours .
If you cant find that # and want it i will sell it...
That should be damn close
Ok, can u post
Pics of all 4 sides and top And bottom
The Vanath TQ guide is pretty good
6410 comes up 440, 73 Truck AT
A 6322 I have is also 440 , 73 truck,AT
The 6455 come up 74, 360 HP
So yes I am interested
Edit
It appears that the carbs are the same except for jets, rods, and brass metering tubes
The 6322 is a CA carb with a vent tube, won't work
The 750 is 1 3/8
The 800 and 850 are both 1 1/2.
The 850 are all Competition Series Cars with a
different Primary boosters than the production 800 carbs
as i recall.
The 1000 are 1 1/2 but with a different booster set up.
This is from memory as I am Out of State Consulting this week.
I will look thru my 100 plus Thermoquads for your # when I get Home next week.
The 750 is 1 3/8
as i recall.
That's the kind of info I'm looking for John, thank you
I'm hoping you have a 6455 or another match to the other TQ''s I have
I'll post the carb numbers of the ones I have later
