femtnmax
Any of these carbs could have the primary throttle shaft bushings renewed. This is easy to do using thinwall valve guide inserts swaged in place and reamed to fit.
These carbs all need a complete cleaning and rebuild kit, not too hard to do really.
Brass floats available on Ebay.
I have described the condition of these 40 year old carbs as best as possible.
The first person that makes payment owns the carb.
SOLD #6139
1972 340, auto, federal
4098 & 5137 primary/secondary jetting. These are OEM for 1973 340 TQ carb.
1966 metering rods, OEM for 1973 340
Good working order
Has correct early style Mopar reman float bowl, looks in very good condition,
All linkage present and working
All internal parts present
Throttle shafts rotate freely thru entire range of motion
Idle mix screws turn freely
Suggest replace the foam floats
In decent condition, look at the photos
Includes replacement metering rod tree with good adjuster
Unopened correct Hygrade carb kit #657C can be purchased with the carb
Carb $25, kit $20 OBO
Early production non CAS (clean air system) carb float bowl cover. No float bowl vent to charcoal canister. Includes early style float bowl that needs work or good for parts.
$5 OBO
#9114
1977 440, auto, Canada
correct jets for this carb 4098/5137/2159 pri/sec/rod
Good working order
Has correct later style float bowl, Mopar reman in good condition no damage
Throttle shafts move freely thru entire range of motion
Idle mixture screws turn freely
Carb $20, kit $20 OBO
SOLD #6139
Good working order
$5 OBO
#9114
Good working order
