Thermoquad integral choke adaptation
DionR
Spokane, WA
I swapped some Magnum R/T heads (the real MP ones) onto my Duster motor with an M1 dual plane and a Thermoquad that matches the car ('74 Duster 360 4 speed). The M1 doesn't have a choke well and so the car has been a bear to start each time I've done so (hasn't been on the road long). Usually, it involves lots of manually closing the choke and cranking, getting tired of it.
So, this last Friday I picked up a 9811 Thermoquad because of the integal choke so I could retrofit it onto the carb on my car. On a side note, it turns out that this is an aftermarket Thermoquad, not a stock one, for use with EGR.
I'm working on building a mount, but while I do so, just wondering if there are any instructions on how to set up the choke, like how many turns to give the housing and such. Any where to by extra parts? This one looks like it might have been tweaked some.
I've tried Demonsizzler and the thermoquads.com website repeatedly and can't get him to repond to my emails, so don't point me there. No hard feeling, I know he kind of closed down his business, just saying that I've tried that avenue for a couple of months and it seems like a dead end.
Thanks.
Thanks.
I have not had any contact from you. My email is:
plymouthrod@yahoo.com
Phone # 770-500-5413
If I can help you, please use above contact info, David.
if you need top of the line TQ help call the guys at southern carbs 601-400-3716 the best service and most honest folks i have dealt with in a long time they did me right fixed me up with just what i was looking for and they stand behind everything they say and DO and then some the thing is that i didn't take there advice the first time and it set me back but they are such good people they helped me get back on track didnt charge me anything extra, can't beat that so give them a call tell them a satisfied customer sent you!
David,
I apologize, I wasn't trying to call you out or anything. I was just trying to anticipate the responses I would get and figured I would say up front that I had tried to get a hold of you. We probably just didn't connect.
I had no hard feelings and wasn't trying to poke at you.
Sent you an email.
David,
Sent you an email.
No problem, just trying to update you with my contact info; sending you an email response right away.
Also to let everyone know, I am running a 'special' price on all ThermoQuad builds right now:
I am offering rebuilds for stock, street/strip and full race for all
models: 4972/4973, 6000 series and all 9000 series including the 9800 series SuperQuads.
Mind you, these are not restorations but I am offering FREE hi temp
detailing(***see before/after pics***)with each build and custom fitted bushed throttle shaft on both ends. This deal also gives the discount price of:
$175 for a stock build,
$195 for a street/strip build,
$235 for a full race build.
Send all inquiries to: plymouthrod@yahoo.com
or call David: 770-500-5413
I will help you choose the best build based on your engine/drive line specs and your needed performance level. These builds will give you max performance and gas mileage!
Got a mount built for an integral electric choke from a 9800 series carb. Still need some work, but getting there.
It's been working good. I wish it was a little stiffer, but it seems to work fine. Had some problems with the lever on the carb sticking, but since I got that fixed it's been great. Put about 3000 miles or more on the car this summer and never even thought about it once I worked a couple of bugs out.
Oh, and I had to bend a new fuel line, too.
I do wish I had I could find a new choke cover, though.
