I am just throwing this out there to see if there might be any interest if I go through with this. I have a fresh 340 with a minor intake sealing issue. Since I have it on the stand I am considering going big block for more power instead of spending more time with this engine. Has not even been out of the garage. The 340 has a .030" overbore, factory steel crank turned .010' under on mains and rods. lunati voodoo 268 cam, SRP pistons, total seal rings and rotating assembly has been balanced. Heads are 65cc with Ferrea stainless valves, bronze guides, lunati springs matched to cam, Lunati 10* locks and retainers and have been gasket matched on the intake side. Hughes engine aluminum rocker arms and shafts with the heavy duty hughes retainers and studs. Also a set of Smith brothers pushrods. Intake is an Edelbrock airgap. What would this engine be worth as is or should I just part it out.
