This is a handy boost calculator for Roots type....But I have some questions
Will go into this 95 Dakota.
I believe Blower speed will be around 12000rpm with a 6" crank pulley and a 3.05" blower pulley. Camshaft is 1200 to 5700 RPM range
Good luck with those teflon strips. We kept blowing them out of our B&M unit. We finally had the strip grooves welded up and clearanced the rotors ourselves and never had another problem.
Hoping the 5-6 psi of boost workload on this small blower will not cause problems. I went with a milder cam just for ease of drivability. I also hope not spinning the engine past 5700-6000 rpms will keep the belt from throwing.
Anyone know what I should enter in for blower efficiency?
That’s a very hard parameter to “know”. How sealed are the rotors? How tight is the housing? Are the end plates scored or new? The highest you’ll likely ever see is around 75% new at low pressure ratios. Realistically 55-60% would be a good guess. Roots blowers are inefficient and really good at making hot air.
Thank you.
I did spend some $$ to have a shop go thru it They gave it an excellent bill of health and then added American brand bearings and seals. I had them machine the rotors for those Teflon strips. DMPE said it was in excellent shape.
DMPE | Supercharging the 21st Century
If the cases are in great shape and you had them strip it with teflon then you’re doing about as good as you can do. You could probably safely estimate 70% efficiency for a while at low pressure ratios.
