Throttle bracket....
Sublime69
Chicago
So whats every one using for a throttle bracket?? I need to buy one for my car and dont know which one to get. Do i need a different kind for an M1 magnum intake? and i have a lokar kickdown cable.
Thanks
What is important is what type of hold clamp your cable needs.Does it have a snap in cable like a GM,a side clamp like a mopar,or some other type,Mrmopartech
I use a lokar throttle and kickdown cable setup, but I use a summit cable mount for a holley. I just mounted the kickdown mount upside down on the bracket. It's nice because no matter how high I mount the carb it's in line.
Can you have a link for that bracket? ans how do you like the lokar throttle cable?
I have a mopar one but i dodnt know if i should get a locar or what.
I used one of the above type brackets and it bent after awhile.
ARE makes some nice brackets. You can get them from Magnum HP and Mancini Racing. The magnum heads will need a specail bracket because of the intake bolt angle.
I use the Jegs bracket also......awesome.....I use the matching fuel pressure regulator bracket too
