throttle brackets
northeastmopar
Massachusetts
Any pictures of throttle brackets for Holley carbs on your small bloc k with a 727 tranny?? I am looking to replace the stock brackets with a nice functional bracket that works good with the throttle cable/return springs/tranny kickdown rod? Any air cleaner interference??
Mine is on a big block, but it should work the same. The bracket is made by TrickFlow and the throttle and kick-down cables are Lokar.
Mancini sells a nice adjustable tall stock looking throttle bracket and return spring and mount. I run them on my small block and have them for the my big block install currently going on.
Thanks, and that is an awesome looking motor.
Im using the mancini bracket and the moroso return spring kit on my 416 so no pics.
