throttle cable bracket
furydan
not so junior member
east of cincinnati, ohio
So I have a 318 with a 4 bbl carb and a 4 speed trans in my 65 barracuda. What does the throttle cable bracket look like for this set up? The one I am currently using looks like it was for an automatic trans from a different year. My throttle cable is at an angle to the carb..Hard to explain without a pic, but does anyone have a pic of the correct bracket for this application?
Yeah, mine looks totally different. The cable actually mounts to the other side of the small hold down clamp and it is taller than yours. I guess now I know what I am looking for. Thanks for the pic and if anyone has an extra, I would like to buy it.
Dan
The picture is of an automatic- is the 4 speed the same? Echo- I need one for an automatic..........2nd in line.... thanks for taking the time to load the picture....
I will be out of home until Sunday but let me look if I have one for you. Do you need a four barrel bracket too or a two barrel?
Here's a stock 66 4-speed setup-
