Throttle Cable Needed
djwhog
Ok I know many of the A body cables will fit. But anyone have an idea where I can purhase a new cable from?
The car is a 64 Dart V-8. But I think I could use a later a body 68 or so with a 340. I think they are a little longer and will reach better on an Air Gap intake.
thanks!
thanks!
I just bought one from Buchillion Performace for $37. Just make sure if you have a square hole, or a round hole where the cable passes through the bracket. I believe the square ones are post-`71. Your `65 *should* be a round end.
http://www.bpemopar.com/
Richard Ehrenberg, a writer for Mopar Action, sells them on ebay and can supply about anything you need. Just type in mopar small block throttle cable on ebay and you should see some of his cables. Contact him if you don't find what you need and he can supply. I had to use a hard to find cable on my 66 and I bought the spare from him.
