71Duster
I recently swapped my Lokar cable out for the factory type kickdown linkage. I just never liked the way the lokar cable made the tranny feel.
At any rate I put the mopar to demon linkage on the carb and went to hang the throttle cable on and theres not enough adjustment in it. I'm about 1/4" from where the stud used to sit so with the adjustment I can make I end up at 3/4 throttle with the peddle to the floor or if I adjsut at WOT I ended up holding the throttle plates open just enough. Does anyone know what the correct throttle cable length is for a 71 Duster 340 automatic?
