Throttle/kick down linkage question
Pumpkinduster
Oregon
I am looking for someone that is running a small block with an edelbrock carb. I’m trying to figure out the proper way to attach the throttle and the kick down. I purchased the Chrysler adapter as well as the needed studs EDL-8007, carb is a 1405. I just want to make sure I get this all setup right. Also if you have pictures of your spring setup for kick down and throttle return.
Here’s how it should look. 318 with a 1406, Chrysler adaptor and 4bbl kick down rod from the throttle bracket to carb.
This article applies to both Holley, Edelbrock, and Carter....
How to set up a Holley 4 bbl for a Mopar
are you running a stock intake or spacer? raising the height of the carb can mess with things
I bought the adapter used my stock two barrel kick down rod cut it made it a little longer I think a inch longer, works great.
