[Found!] Throttle return bracket made out of unobtainium Slant 6
gdizzle
los angeles
I am still searching for the throttle return bracket for my slant 225 (66 dart), converted to super six setup. you know the bracket I need. Currently using a blade remover tool from my power saw, almost the right size, but looks so ghetto.
i should have with with my setup. i can trace it to make a copy maybe design a cnc cad file to make it?
If it's what I think you should be able to cut it out of flat stock from a pattern, and then just give it a few bends in the vise. I temporarily subbed a simple 90º angle bracket before I found the one I knew I had somewhere....
Is this the one?
Part of my setup but I can measure and should copy fairly easy I think
