68Fastback402
Member
These Mopar Performance 402 c.i.d. Magnum crate engines are "square" in engineering terms, meaning that they have identical 4.00 in. bore and stroke dimensions. However, with 435 hp on tap, no one is ever going to accuse them of being boring. Pair one up with your ride, and you'll get a barrel full of excitement. They're built with high quality parts, featuring Magnum R/T cylinder heads with big stainless steel valves (2.02 in. intakes, 1.625 in. exhausts), heavy-duty valve springs, and a surprisingly civilized 9.0:1 compression ratio. The intake is a tall, single-plane, single 4-barrel M1 type. It has paired runners separated from each other and the base of the manifold by large air gaps intended to deliver a cooler, denser air-fuel charge. The manifold also has molded-in bosses to allow conversion to fuel injection, including MPI components. (However, these engines are not recommended for use with the stock, factory MPI system itself.) The camshaft is a hydraulic roller type, with a 0.501 in. intake lift and a 0.513 in. exhaust lift. Intake duration is 288 degrees; exhaust, 292 degrees. The engines come with a Mopar electronic ignition and distributor, a center-sump oil pan (similar to a Commando engine), Mopar cast-aluminum valve covers, and a double-row roller timing set. They're not for use with air conditioning, and the manifold is taller than stock, so check hood clearance.
I was wanting to find out the best timing everyone seems to like ?
Also thinking of porting my heads or best heads that will wake her up
