red cuda
whats the gains in having a double roller over a single? I got a new single roller in a rebuild kit that I bought. would that be sufficient for a very mild street engine?
i think so.
The only gains that a true double roller chain has is strength to pull the valvetrain along. High spring pressures, etc.
You will be fine. You may want a v6 tensioner to help keep timing steady, but all chains benefit from that.
Put it in and drive it.
